Stainless baffle, radiator support bracket.
Posted By 55charliebird 6 Years Ago
55charliebird
Posted 6 Years Ago
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
QUESTION....is the baffle necessary with the Casco HO pump. I doesn't appear to fit because the impeller is bigger than the original water pump impeller.
QUESTION...where can I get a replacement radiator support frame or should I have it repaired..
Posted 6 Years Ago
Posts: 3.7K, Visits: 497.8K
Depending on how bad yours is, repairing may be the least expensive option.
I don't think the radiator support frame is available repro.  Contact the various TBird parts suppliers for a good used one  (CASCO, Hill's)
55charliebird (3/3/2019)
Posted 6 Years Ago
If you are talking about the stainless steel baffle that is an aftermarket piece, that will not work with the Casco water pump.  The Casco water pump impellors reach much further into the water pump cavity thus promoting additional water flow into the back of the timing cover and then into the block.  As mentioned previously, those baffles do not help with the Thunderbird cooling issues and in many cases simply makes the problem worse.  Leave it out and use it for wall decoration.
