55charliebird (3/3/2019)
QUESTION....is the baffle necessary with the Casco HO pump. I doesn't appear to fit because the impeller is bigger than the original water pump impeller.
If you are talking about the stainless steel baffle that is an aftermarket piece, that will not work with the Casco water pump.  The Casco water pump impellors reach much further into the water pump cavity thus promoting additional water flow into the back of the timing cover and then into the block.  As mentioned previously, those baffles do not help with the Thunderbird cooling issues and in many cases simply makes the problem worse.  Leave it out and use it for wall decoration.
