55 Ford fairlane engine mount
Posted By Robin272 7 Years Ago
darrell
Posts: 455, Visits: 22.2K
these are old original mounts.i have both 6 and 8
Robin272
Posts: 33, Visits: 114
Darrell. I am just curious. What brand is the V8 mount you have and do you happen to know how old they are ?
Robin272
Macs auto are listing a transmission mount 54-56 mercury V8. Do you know the difference between a Ford and a mercury trans mount ? https://www.macsautoparts.com/ford_mercury_late/rear-motor-and-transmission-mount-mercury-312-v8.html
Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)
Last Active: 30 minutes ago
Posts: 3.7K, Visits: 32.7K
The Transmission Mount itself is the same for 6 or 8. Only difference would be Automatic or Standard. If You are only out by an Inch as U stated your best bet would be to move the Transmission forward that one inch and modify the Transmission Mount to go forward One Inch. i still don't understand why its not going together as it should.
Robin272
Yupp. They are corect. I need the right trans mount.
Robin272 (2/28/2019)
Serial No: U5FW216014
64A. YE M. 3FDD305.
Cant find the identification chart inn the shop manual.
First letter "U" is for 272. so the v8 Mounts should have been right.
Robin272
Oh man. Why cant just people do it right the first time 😞 i already have linkage trouble beacause off the mummert intake i have innstalled, and that intake does not have the holes too the factory trottle bracket. Beacause of the fordomatic i guess i will have to fabricate something new here. If i get into exhaust trouble with this swap, i might as well order a rom on the hospital, i just hate exhaust modification. 😞
Robin272
64A. YE M. 3FDD305.
darrell
i should add if you go with the v8 mounts you will have to change a few things.gas linkage trans linkage if its an automatic.motor will be closer to the rad which may not mike a difference.exhaust may have enough play to move.trans mount lots of fun.i would go to the v8 mounts myself but thats up to you.
darrell
mount and crossmember are the same.
