I need help identifying a Bell Housing
Posted By Candyrcode 6 Years Ago
Candyrcode
Posted 6 Years Ago
First Time Poster
Posts: 1, Visits: 117
http://forums.y-blocksforever.com/uploads/images/7cb80066-2c35-49d7-98e5-6852.jpg
Posted 6 Years Ago
Last Active: 8 hours ago
Posts: 7.4K, Visits: 205.5K
Do you have a picture of the engine side of the bell-housing?
darrell
Posted 6 Years Ago
Posts: 455, Visits: 22.2K
automatic bell from a truck.i cant see the bolt pattern so cant say what its for.
kevink1955
Posted 6 Years Ago
Posts: 236, Visits: 237.6K
Darrel,  I do not think it's a truck bell,  the side arms are not mounts, they are air discharges from an Air Cooled Ford O Matic convertor.  Air cooled was used prior to mid year 56 in cars.  Not sure without seeing the engine side but it looks Y-Block.    It has some part numbers on it, if the OP could post them I am sure we could get an answer.
Edit
On a second look the bottom "Ears" do look like mounts, post the casting numbers if you can
2721955meteor
Posted 6 Years Ago
Posts: 927, Visits: 190.0K
1955,and 56 trucks used a oil cooler ,using water from eng,via water  hoses. at least canadian trucks. recently saw 2. could not see what converter they used. i had a 56 and the cooler was attached  via bracket to trans with steel lines for the oil
darrell
Posted 6 Years Ago
i have one of these just went out and had a look.its a 292.i can see enough from the back.the only other it could be is a 223 but its not
