1954 ford truck 239 OHV
Posted By stevie 6 Years Ago
stevie
General Posted 6 Years Ago
First Time Poster
Posts: 1, Visits: 2
I was wondering if any other carb would work on my 239 with manual transmission. I did not know if an intake is available for this engine and also the accelerator hook up. Thanks
Posted 6 Years Ago
Last Active: 9 hours ago
Posts: 7.4K, Visits: 205.5K
Edelbrock made an aluminum intake manifold for the 1954 239 heads but those are like finding hen’s teeth.  The cast iron four barrel manifold from a 1954 Mercury with the 256 engine is a bolt on for the 1954 Ford 239 engines.  if using a modern carburetor in lieu of a Holley 2140 or 4000 (Teapots), early Rochester or Carter, then a carb adapter will be required.  There are still a few of those Merc 256 intake manifolds floating around.
Posted 6 Years Ago
Last Active: 12 hours ago
Posts: 6.1K, Visits: 442.5K
There is an Edelbrock 548 setup on Bay right now but the seller seems to be in a fantasy land.  I see them come up a couple times a year.  Keep looking and a more reasonable one may show up.
There are also big Strombergs which are produced brand new.
Posted 6 Years Ago
Here’s a picture of the Edelbrock #548 intake for the 1954 engines.  This one has been repaired at the front where the thermostat flange had eroded badly.
http://forums.y-blocksforever.com/uploads/images/0e7ac725-50c5-4463-a9f5-a500.jpg
Posted 6 Years Ago
Posts: 1.7K, Visits: 306.2K
And here is a 1954 MERC 256 OEM 4V Intake If you need the reference-
CASTING I.D. NO. - EBY 9425-D
http://forums.y-blocksforever.com/uploads/images/40fba2ff-a5fc-4024-a800-0944.jpg
Posted 6 Years Ago
There is a Merc intake listed for $75 plus shipping on the Ford Y-Block Facebook group right now.
55charliebird
Posted 6 Years Ago
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
I have a ford manifold 2V and a ford 2bbl carb with linkage for that manifold. The pn for the manifold is EBU 9425D.  The carb is Ford EAB.
