54 Rear Rubber Stone deflector Clips
Posted By paul2748 6 Years Ago
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.6K
I am looking for the clips shown in the attached pictures. They are for a 54 Ford and holds the rubber rear stone deflector (goes between the body and the bumper). Tried Restoration Specialties and they don't have them.
The U shaped one is 3/4 ' long, 5/8 wide and about 1/4' at the "U".
The 55's and 56's may have used the same clip
Only need the U shaped one
PM or email me, Thanks
http://forums.y-blocksforever.com/uploads/images/fb5cd57d-f508-4ca4-807b-9d84.jpg
Genuinerod
Posted 6 Years Ago
Posts: 120, Visits: 33.3K
In looking at my books, the only clip I found for the rear stone defector is part number 357563-S2 (GG32).  It calls out 6 clips for cars 1952/1954.  Don't know of any place for these but there should be similar clips that may work.  The T-Bird catalogs have some clips for wiring and brake lines that may work for you.
Posted 6 Years Ago
Posts: 1.7K, Visits: 340.0K
I've had my 56 rear bumper off a few times. The rubber seal is attached to a light weight metal frame with staples which attaches to the car with tabs to the bumper bolts. No clips as shown.
Posted 6 Years Ago
Thanks - I was hoping the 55 and 56 cars had the clips.  .
DryLakesRacer (2/14/2019)
Posted 6 Years Ago
Thanks for suggestion about possible  TBird clips as a substitute
Genuinerod (2/14/2019)
thunderrolls
Posted 6 Years Ago
Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)
Posts: 6, Visits: 33
The left clip look a lot like a wiring harness retaining clip on my 62 TBird that hold the wires on the cowling inner lip under the hood. I haven't seen anything that looks like the other
vintagepartsource.com/bodytrim.htm give a long list of business that you should contact to see if any of them can help you out
Hope this help you out
Posted 6 Years Ago
