By paul2748 - 6 Years Ago
I am looking for the clips shown in the attached pictures. They are for a 54 Ford and holds the rubber rear stone deflector (goes between the body and the bumper). Tried Restoration Specialties and they don't have them. The U shaped one is 3/4 ' long, 5/8 wide and about 1/4' at the "U". The 55's and 56's may have used the same clip
Only need the U shaped one
PM or email me, Thanks
By Genuinerod - 6 Years Ago
In looking at my books, the only clip I found for the rear stone defector is part number 357563-S2 (GG32). It calls out 6 clips for cars 1952/1954. Don't know of any place for these but there should be similar clips that may work. The T-Bird catalogs have some clips for wiring and brake lines that may work for you.
I've had my 56 rear bumper off a few times. The rubber seal is attached to a light weight metal frame with staples which attaches to the car with tabs to the bumper bolts. No clips as shown.
Thanks - I was hoping the 55 and 56 cars had the clips. .
DryLakesRacer (2/14/2019)
Thanks for suggestion about possible TBird clips as a substitute
Genuinerod (2/14/2019)
By thunderrolls - 6 Years Ago
The left clip look a lot like a wiring harness retaining clip on my 62 TBird that hold the wires on the cowling inner lip under the hood. I haven't seen anything that looks like the other vintagepartsource.com/bodytrim.htm give a long list of business that you should contact to see if any of them can help you out Hope this help you out
