Original power brake booster
Posted By 55 GLASS TOP 8 Years Ago
Lord Gaga
Last Active: 9 Months Ago
Posts: 470, Visits: 183.3K
KULTULZ (12/17/2018)
https://www.npdlink.com/product/block-manifold-vacuum-connection/167469/220640
This fitting(s) is for BIRD.
FORD is 354316-S
EDIT -
Notice NPD shows two different fittings under the same PN. One is 1956 and the other 1957. You have to know what you are looking for exactly as the vendor may have no idea or incorrect listing(s).
Basic PN 17597 is a vacuum source for the wiper motor without a two stage fuel pump. The fitting is also described under BASIC 17597.
All of this depends on the year (55-56-57) and what accessories were assembled on the vehicle (whether FORD or BIRD). Most info was deleted from cataloging. You would need period cataloging and most likely an ENGINE ASSEMBLY MANUAL to figure out each assembly detail.
THIRTY BILLS?... for a Weatherhead fitting?!! Is brass the new gold?Crying
"FREE SAMPLE"
Posts: 2.0K, Visits: 306.6K
I paid no attention to the price. And that is for two according to the ILL.
Now they also sell the 56 fitting by itself for 32.35.
You gotta watch these guys.
NAPA should have it.
56_Fairlane
Posts: 575, Visits: 14.6K
In the case of the manifold brass fitting, I'll probably search ebay for it. Macs doesn't seem to have it. I found everything else I need from them. So far my total is just over $100 which will get me free shipping. If I spend as much time as I have so far searching for the parts, I should be able to find a good promo code too.
~DJ~ AKA "Bleach"
Posts: 3.8K, Visits: 33.3K
Whats the Part # You are looking for?
You want some more aggravation?
This is a INSTRUCTION SHEET from a 1956 BOOSTER INSTALL KIT. VIEW 9 shows going from a two port fitting for a three port (booster - wipers - dual adv dist canister)  Much varies on how the engine was assembled OEM and what accessories the car came through with.
http://forums.y-blocksforever.com/uploads/images/58969f1d-75f6-43e1-b99b-3b32.jpg
http://forums.y-blocksforever.com/uploads/images/88740547-a4bf-438c-8a58-f3a2.jpg
Parts Catalog Illustrations are not exact copies of ENGINEERING DRAWINGS. They are a culmination of similar years/assemblies. They show just enough so that the PARTS DUDE can find his/her/it/mutant's way in the TEXT.
56_Fairlane
This is the part I'm looking for. I'm not sure of the part number.
Connecting Block - Power/Brake - Manifold 57 - 1 Per car
Kultulz, do you have a better resolution copy of the installation diagram? If you're not able to post it, could PM it to me or I could PM you my email.
~DJ~ AKA "Bleach"
That looks like 2 Parts not One. Is Part(s) #'s not shown in Illustration?
56_Fairlane
Casco has this part for $35.65. http://www.classictbird.com/Connecting-Block-Power_Brake-Manifold-57-1-Per-car/productinfo/354447CS/
They list some part numbers but they're probably they're own number.
~DJ~ AKA "Bleach"
They are using the original Ford #. 354447-S. Same # Tee-bird has. Macs don't have One?
No, wish I did. I stumbled across that one on GOOGLE. Maybe print it out it will be larger? Were you able to read VIEW 9?
The fitting you are showing is for a 1957.
