Visits: 270
could not find the answer , what is the correct color for the 1954 239 y block and accessories , water pump , starter , timing housing etc ????
The block, pan, timing cover, intake, and heads are an Ivory White color. I’m told Packard Cream comes close. Martin Senor #99L-11562 almond color supposedly comes close to the original Ivory White. The valve covers are red. The starter, generator, and pulleys are black.
Last Active: 4 days ago
Posts: 1.0K,
Visits: 164.5K
Unless it’s a truck, then it’s different.
Dennis in Lititz PA
Dennis. Thanks for the clarification. I did mean the cars with the Ivory White engine color.
Posts: 2.0K,
Visits: 306.6K
Partial Photo-
Visits: 498.2K
Bill Hirsch in NJ has the Packard color in engine paint. Close to the original 54 color
Visits: 153.3K
Not to change the subject, but why is there a ball of aluminum foil on that air cleaner?
Posts: 3.8K,
Visits: 33.2K
Tedster (11/17/2018)
Not to change the subject, but why is there a ball of aluminum foil on that air cleaner? Perhaps it was being used to check Air Cleaner to Hood Clearance when closed? I have used PlayDoh for same Purpose.
Posts: 2.0K,
Visits: 306.6K
Engine Steady Rest -
Visits: 153.3K
I thought as much, but figured everything was stock and clearance shouldn't be a problem. Neat trick though. I like the contrasting bright colors in the old Fords, it really "pops".
