low brake pedal
Posted By geo56 8 Years Ago
There is probably a specification for pedal height in the shop manual.  Checking that will give you a clue.  If it is too low, then maybe that bushing is missing, maybe the wrong pushrod is installed, maybe the pushrod hole is too deep in the replacement cylinder, maybe the location that it connects to the pedal has been changed due to a previous owner's bright idea, maybe a pedal return stop is adjusted incorrectly.  If height is good, then it probably is not linkage or actuation related.
