Posts: 2.0K,
Visits: 306.6K
Here is a simple and cheap kit -
geo56
Visits: 7.6K
The likely cause that you posted was blocked out by the shop manual picture . Please reply again. thanks
Posts: 3.8K,
Visits: 33.3K
KULTULZ (11/4/2018)
If you are not going to disc/drum and still using a SGL RSVR MC, why the adjustable proportioning valve? Also be careful here as using two residual valves in tandem can cause serious problem(s). The Adjustable Prop Valve was recommended as part of the Purchase to allow fine "tuning" the Front and Rear Brake Bias. I had One on the last 56 when I added Disc Brake and found it very useful. I have asked for clarification from the supplier on whether or not there is a Residual Valve in the new Master already. If there is I don't need to ad another One.
Posts: 2.0K,
Visits: 306.6K
oldcarmark- The Adjustable Prop Valve was recommended as part of the Purchase to allow fine "tuning" the Front and Rear Brake Bias. I had One on the last 56 when I added Disc Brake and found it very useful" A proportioning valve is not used on four wheel drum. Brake balance/bias is achieved by shoe and wheel cylinder size.
Talkwrench
Visits: 23.2K
geo56 (11/3/2018)
All parts were ordered from Concours at the same time: new master cylinder, wheel cylinders and brake shoes. After 10 years it might be a good idea to replace all again with original equipment if I can get it. I think you'll find the linings would of been generic , and if your drums are oversize they will never fit well or work. You need to take your drums to a place that does linings and have them measure and use correct oversize linings . You dont need to bench bleed a single Cyl master Cyl. DONT push the pedal all the way to the floor in a single either. Buy speed bleeders and make your life easy.
Visits: 498.2K
Residual pressure valves are usually found only on drum brake masters. Disc/drum masters usually use a combination block (residual pressure and prop valves) lThe Adjustable Prop Valve was recommended as part of the Purchase to allow fine "tuning" the Front and Rear Brake Bias. I had One on the last 56 when I added Disc Brake and found it very useful. I have asked for clarification from the supplier on whether or not there is a Residual Valve in the new Master already. If there is I don't need to ad another One. [/quote]
Posts: 2.0K,
Visits: 306.6K
When all the dust and smoke clears, it is usually improper shoe adjustment. If after a proper adjustment you don't have a good pedal, you go further (after allowing proper shoe seating).
darrell
Visits: 22.3K
2 inches of brake pedal is just as good as a full one..your shoes not fitting the drum has nothing to do with how much pedal you have.
darrell
Visits: 22.3K
i forgot to add bleeding your master cylinder will not help.you only do that when putting on a new master and dont want to bleed your wheels.if your wheels are bleed properly only 2 things are left wrong master cylinder or the rod is to short.what did you have for brakes before you done them over.
Posts: 2.0K,
Visits: 306.6K
 ...'ya know ... This is exactly why I try to avoid brake theory discussions ...
