Visits: 3.9K
Pete,
Is yours the same as above photos? If not, can you post a photo of your setup.
Thanks & regards, JLB
Visits: 93.2K
Visits: 93.2K
JBL, you call we haul, Have a great Thanksgiving Pete
Last Active: 10 Months Ago
Visits: 183.3K
Pete 55Tbird (11/22/2018)
Where does that copper tubing attached to the road draft pipe lead?
"FREE SAMPLE"
Visits: 3.9K
Pete,
Thanks a lot for the photos!
Interestingly enough, your photos are very helpful; but, now, also serve to confuse me a bit more because your setup is, again, "different" from all the others I've seen in other photos posted here - what a variety!
All the varieties shown have also got to be "interesting" to some other folks here too! I'm hopeful that this information can help someone else too: Perhaps one of the moderators would like to edit some of the photos & information in this thread & place it as a "sticky" for future use for "everybody"?
Regards, JLB
Posts: 2.0K,
Visits: 306.6K
Lord Gaga posted- "Where does that copper tubing attached to the road draft pipe lead?" That is the manifold vacuum source on the 57 ECZ-B intake for booster/wipe rmotor. The line is copper and maybe a gig should be considered ...
Visits: 93.2K
Copper line is in fact manifold to the dual vacuum fuel pump that powers the windshield wipers. I put in on in 1965, it has allowed me to drive in the rain ,and snow when guys with much more "CORRECT" cars park their cars to preserve the ( fill in the blank) Pete
Visits: 93.2K
JLB, keep in mind my throttle linkage is for a Holley 4150 TYPE carb and also controls the 55 aircooled FOM and the KICKDOWN that allows passing gear. Very important, almost vital for this set-up. If your glasstop has a FOM YOU NEED THIS feature. Do your homework NOW and not after. Good luck Pete
Visits: 183.3K
Oh, My bad. Looked like it was attached to the road draft pipe!
"FREE SAMPLE"
Visits: 3.9K
Folks,
My sincere thanks to two people who were both very helpful with both photos and offers of parts: Carl & Oldmics. They sent various photos and other information. And I had phone conversations with both, too!
I'm very appreciative to both!
I've now purchased some parts from Oldmics; and, hope that I can "kludge" working linkage together with those and other parts.
Regards, JLB
