Visits: 557
Hi, guys... I bought a pair of ECR heads... What are the specs on this Heads? I read they had the same intakes valves likes 1957's models 1.92" and the exhaust are Sodium filled... Exhaust valve sizes are? Low compression heads, large Chambers? Thanks in advance... Leandro
I got a Hot rod Ford and two dollar bill... WhatsApp +54 9 3496 512986
Last Active: 2 Weeks Ago
Posts: 1.9K,
Visits: 194.9K
Here’s a link to the head chart, lots more tech info on John Mummert’s site http://www.ford-y-block.com/cylinderheadchart.htm
Visits: 557
 My Pile 😊
Posts: 1.4K,
Visits: 179.6K
Ratamahata. Cliff is a regular contributor here on the Forum. Click the link below to see some info he posted on the ECR heads a couple of years ago. http://forums.y-blocksforever.com/FindPost125342.aspx
Visits: 13.5K
ECR Heads are very low compression (large chamber), large port, big valve (all that I have seen), these came on H/D 272 Engines, not good for anything short of supercharging.
Visits: 557
Many thanks!! If someone now what could be the compression? 8 to 1 or less? I appreciate your help!
Visits: 557
 292 HD truck combustion chamber  Ford 292 (Phase 1) made in Argentina As you can see in the images there's a big difference in the combustion chambers heights... Argentinian made Y block only 6.5 to 1 compression...
