Just finished my fuel tank
Posted By LordMrFord 7 Years Ago
LordMrFord
Posts: 687, Visits: 9.3K
http://forums.y-blocksforever.com/uploads/images/2ebb6d0c-dd91-4317-bf5f-a214.jpg
Don't know why, but there is no aluminum tanks with baffles, sump and dual inlets and outlets for '59 Fairlane, so I did one for myself.
Welding is not great but this is my second project after I bought a Tig welder.
Hyvinkää, FI
Last Active: 58 minutes ago
Posts: 6.1K, Visits: 442.8K
Cool.
So, does it actually hold gas?  If any of the welds are bad, it will leak.
Cliff
Posts: 878, Visits: 13.5K
Good work
Rono
Posts: 1.3K, Visits: 80.0K
Good job! I have a TIG welder and I'm still practicing. Afraid to try on anything of value. What type of filler rod did you use and what Amperage?
LordMrFord
charliemccraney (10/22/2018)
Cool.
I pressure tested it with air and soap water. Looks airtight.
Hyvinkää, FI
LordMrFord
Rono (10/22/2018)
AC, 2,4mm green eletrode, 1,6mm AlMg5 filler rod, maybe 120Hz, 30% cleaning, about 110A, #7 to #8 gas lence(melted my #8 without gas, doh) and pure argon 10l/min. 4mm aluminum plate.
Welding whole tank took about 4kg argon.
Hyvinkää, FI
