By LordMrFord - 7 Years Ago
Don't know why, but there is no aluminum tanks with baffles, sump and dual inlets and outlets for '59 Fairlane, so I did one for myself. Welding is not great but this is my second project after I bought a Tig welder.
Cool. So, does it actually hold gas? If any of the welds are bad, it will leak.
By Cliff - 7 Years Ago
Good work
By Rono - 7 Years Ago
Good job! I have a TIG welder and I'm still practicing. Afraid to try on anything of value. What type of filler rod did you use and what Amperage?
charliemccraney (10/22/2018)
I pressure tested it with air and soap water. Looks airtight.
Rono (10/22/2018)
AC, 2,4mm green eletrode, 1,6mm AlMg5 filler rod, maybe 120Hz, 30% cleaning, about 110A, #7 to #8 gas lence(melted my #8 without gas, doh) and pure argon 10l/min. 4mm aluminum plate. Welding whole tank took about 4kg argon.
