368 LYB transmission swap
Posted By moody jim 7 Years Ago
moody jim
Question Posted 7 Years Ago
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 3, Visits: 9
Is there a later model automatic such as a C-6 that will fit a 368?
darrell
Posts: 455, Visits: 22.2K
no for the c6 but you should be able to use an fmx.
Last Active: 10 hours ago
Posts: 1.8K, Visits: 306.3K
There is no direct bolt-on other than the TURBO-DRIVE (FORD-O-MATIC derivative) or the earlier HYDRA-MATIC 4/S Direct. Anything else will require an adapter.
darrell
the fmx is an easy swap as long as you have the bell torque converter and flywheel from 55 to 57.use the front pump from the l368 on the fmx and drill out 2 top bolt holes and your in.you need the long fmx from an ltd or truck as the smaller cars have a short tailshaft.john has one in his 57 ford.
"the fmx is an easy swap as long as you have the bell torque converter and flywheel from 55 to 57.use the front pump from the l368 on the fmx and drill out 2 top bolt holes and your in.you need the long fmx from an ltd or truck as the smaller cars have a short tailshaft.john has one in his 57 ford."
... hmmph ...
Interesting, and had no idea. So a FMX main case will go to a LYB TURBO-DRIVE bell with a front pump modification.
What holes have to be drilled? Is there any TECH INFO on this?
darrell
i had an fmx in my last 56 ford.looking at a lincoln transmission i can see no difference between it and a mercury trans.the case looks the same size but i havent done it myself.im sure someone on here has.
OK. When we talk FMX, we are describing the 1968/ iron main case trans, right?
darrell
yes
Posts: 6.1K, Visits: 442.8K
Here's an article about adapting an FMX.
http://www.y-blocksforever.com/tech/html/fmx_upgrade.html
If you search the forum for FMX and user name Hoosier Hurricane, you'll probably find more buried in the forum.
moody jim
Posts: 3, Visits: 9
thank you
