Generator light
Posted By Moz 7 Years Ago
Tedster
Posts: 513, Visits: 153.3K
Yes, that's true. I bet they tweaked it up and down as part of the "twice a year" tune-up. I also read somebody who worked maintenance at a large dealership back when generators were widespread, I think he said out of all the mechanics who worked there (a bunch) only two were ever allowed to make voltage regulator adjustments. The manuals do have the procedure but it takes some practice.
What would happen too, lots of in town, stop and go, idling, or night driving would lead to a discharged battery. A bit higher voltage or current output helps in this situation, but that same car would then overcharge and boil the battery out if taken on a long trip. Different size pullies make a big difference as well. I think voltage regulator adjustment should be looked at as kind of a last resort, it's more likely with collector or vintage cars that corroded ground cables and wiring connections would need to be remedied before messing with the regulator itself.
If there's a solid state generator regulator out there other than the Bosch VW unit, it's pretty rare. The Clover Systems apparently went bye-bye.
Moz
Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)
Posts: 533, Visits: 3.7K
there lies the problem with going to an auto elec, in my town anyone of them that understood generators are long gone.
moz. geelong victoria australia.
graduate 1980, bus, truck, car, hot rod, boat, submarine, hovercraft, hydrafoil, firetruck, mobile home, jet, helicopter, cruise ship, motorcycle, bicycle, santa's sleigh, clock, alloy bullbar, alloy fuel tank, lens, dr who's tardis, matter - anti matter warp drive buffer & y-block lover
Tedster
Moz (10/6/2018)
Here's your opportunity to take up the mantle! Tell those kids to stay offn yer lawn, too! You can be "that guy" and help your fellow cranks out.
I found reading up on them helped a lot, good info is kind of scarce, but it's available if you dig on the vintage auto websites and some of the tractor forums, but there's no substitute for getting grease under your fingernails. Shop manual is essential and a good analog voltmeter. The old manuals cautioned that a defective generator or charging system meant a satisfactory tune-up would not be maintained over time as the battery will become weak, and the ignition system starved for current under high speed or load.
slumlord444
Posts: 1.2K, Visits: 137.8K
I just got the charging system working again in my '57 Bird. Went through 4 voltage regulators before I got  one to work. US made bought off EBay. one from local parts store died after a short time. Two from Rock Auto did not work. So far so good. Good luck with yours.
Last Active: 1 hour ago
Posts: 1.8K, Visits: 306.3K
"The old manuals cautioned that a defective generator or charging system meant a satisfactory tune-up would not be maintained over time as the battery will become weak, and the ignition system starved for current under high speed or load."
There 'ya go. It has to have a solid basic BAT and charging system or it will not have enough reserve to operate the IGN adequately.
Used to be ... that the electrical BAT and charging system checkup was the first step in a basic tune-up.
"Went through 4 voltage regulators before I got  one to work. US made bought off EBay. one from local parts store died after a short time. Two from Rock Auto did not work. So far so good. Good luck with yours."
There were also different rating VR's for the car GEN AMP output. I don't know how that is handled in today's aftermarket.
