By Moz - 7 Years Ago
Just put a new voltage regulator on the ute, the old one had an intermittent fault it would only work sometimes, the new one is from Dennis Carpenter and since fitting it I now have a gen light that starts to glow as the revs build (around 3500-4000 rpm), following their instructions I polarized it and it does put a quick charge into the battery after starting but then drops to 12.50 volts and stays there even when I have all the lights on. I've never had the Gen light come on before I fitted the Carpenter regulator, has anyone else had a problem with them ?
By Tedster - 7 Years Ago
What is the condition of the generator itself? Brushes cause a fair amount of trouble. There are simple troubleshooting procedures that can be performed to isolate to either the generator or regulator. Analog voltmeter is preferred. An ammeter capable of measuring at least 30 amps is necessary, though you can maybe get away without that. This troubleshooting is where the shop manuals come in handy.
Be sure to use only the Ford or type "B" tests and connections or risk ruining the regulator. Generator output test (current) is one test, the field should also be tested for a couple volts output, you can try "motoring" the generator (this also polarizes it, incidentally) and a "full fielding" test.
one brush in the gen was no good I replaced both and polarized the generator, all of the tests in the workshop manual except the ammeter ones have been performed, the generator is well within specs, when I get a chance on the weekend I will put the old reg back on and see if the light glows when I accelerate, I will also see if on my tunescope it has an ammeter, hopefully I can have some more answers then
By Lord Gaga - 7 Years Ago
Have you checked your battery cells with a hydrometer?
Brand new battery
By 56Roger - 7 Years Ago
I like to solve problems myself whenever possible as much as anyone. But when it comes to some aspects of automobile electronics (even the old stuff) I learned a long time ago the best thing may be to take a trip to an auto electric shop. Sooner than later. Have had a few problems that I hadn't solved fixed in minutes for hardly any money. No wasted and possibly expensive parts changing and other unnecessary fooling around.
"Oh you just need to do this."
Done.
Happened to me two or three times over the years. Enough to make me wise up. And learn something at the same time.
By KULTULZ - 7 Years Ago
"...the new one is from Dennis Carpenter and since fitting it I now have a gen light that starts to glow as the revs build (around 3500-4000 rpm), following their instructions I polarized it and it does put a quick charge into the battery after starting but then drops to 12.50 volts and stays there even when I have all the lights on."
Is it a mechanical VR? Any mention (instructions) of it's needing to be adjusted to the GEN?
A new battery is not always fully functional.
56Roger (10/5/2018)
I like to solve problems myself whenever possible as much as anyone. But when it comes to some aspects of automobile electronics (even the old stuff) I learned a long time ago the best thing may be to ....
Yes, but most of the graybeards are just about retired at this point or at the Whispering Pines by now. Even some of the independents who are still around though old enough to have some knowledge base it just seems like they really don't want to be bothered with it. If you CAN find a motor shop, I would agree. Take both the regulator and generator in and they can set it up.
KULTULZ (10/5/2018)
"...the new one is from Dennis Carpenter and since fitting it I now have a gen light that starts to glow as the revs build (around 3500-4000 rpm), following their instructions I polarized it and it does put a quick charge into the battery after starting but then drops to 12.50 volts and stays there even when I have all the lights on." Is it a mechanical VR? Any mention (instructions) of it's needing to be adjusted to the GEN? A new battery is not always fully functional.
I wondered about that. At a slow idle, the battery is cutout and 12.50 volts is expected because no charging is taking place. Spool up the RPM to 2000 or so and then measure. If the GEN light is illuminated though, there is a problem.
Generator regulators are "always" mechanical; it is possible to use a VR from a early 70s Volkswagen I'm told, but I haven't tried it. Regulator adjustment is VERY touchy and many a battery or generator has been smoked by the "Golden Screwdriver"; they should be pre-set from the factory and very close to optimum without any adjustment needed unless Mr. Goodwrench has already been in there at some point.
It used to be that a mechanical regulator may have had to be adjusted for season, the VR being sensitive to temp change. Then you had burnt points, sticking and all kinds of possible ailments. Adjustment is described in detail in the appropriate year SHOP MANUAL.
There is a solid state VR available for a GEN..
Yes, that's true. I bet they tweaked it up and down as part of the "twice a year" tune-up. I also read somebody who worked maintenance at a large dealership back when generators were widespread, I think he said out of all the mechanics who worked there (a bunch) only two were ever allowed to make voltage regulator adjustments. The manuals do have the procedure but it takes some practice.
What would happen too, lots of in town, stop and go, idling, or night driving would lead to a discharged battery. A bit higher voltage or current output helps in this situation, but that same car would then overcharge and boil the battery out if taken on a long trip. Different size pullies make a big difference as well. I think voltage regulator adjustment should be looked at as kind of a last resort, it's more likely with collector or vintage cars that corroded ground cables and wiring connections would need to be remedied before messing with the regulator itself.
If there's a solid state generator regulator out there other than the Bosch VW unit, it's pretty rare. The Clover Systems apparently went bye-bye.
there lies the problem with going to an auto elec, in my town anyone of them that understood generators are long gone.
Moz (10/6/2018)
Here's your opportunity to take up the mantle! Tell those kids to stay offn yer lawn, too! You can be "that guy" and help your fellow cranks out.
I found reading up on them helped a lot, good info is kind of scarce, but it's available if you dig on the vintage auto websites and some of the tractor forums, but there's no substitute for getting grease under your fingernails. Shop manual is essential and a good analog voltmeter. The old manuals cautioned that a defective generator or charging system meant a satisfactory tune-up would not be maintained over time as the battery will become weak, and the ignition system starved for current under high speed or load.
By slumlord444 - 7 Years Ago
I just got the charging system working again in my '57 Bird. Went through 4 voltage regulators before I got one to work. US made bought off EBay. one from local parts store died after a short time. Two from Rock Auto did not work. So far so good. Good luck with yours.
"The old manuals cautioned that a defective generator or charging system meant a satisfactory tune-up would not be maintained over time as the battery will become weak, and the ignition system starved for current under high speed or load."
There 'ya go. It has to have a solid basic BAT and charging system or it will not have enough reserve to operate the IGN adequately.
Used to be ... that the electrical BAT and charging system checkup was the first step in a basic tune-up.
"Went through 4 voltage regulators before I got one to work. US made bought off EBay. one from local parts store died after a short time. Two from Rock Auto did not work. So far so good. Good luck with yours."
There were also different rating VR's for the car GEN AMP output. I don't know how that is handled in today's aftermarket.
