Engine numbers.
Posted By 55charliebird 7 Years Ago
55charliebird
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
Where should I look for all the engine numbers....   Do heads have matching numbers?
DANIEL TINDER
Last Active: 4 days ago
Posts: 1.7K, Visits: 154.2K
Check out: John Mummert’s site (ford-y-block.com) for block & head casting #s. ‘Matching #s not a relevant FoMoCo system (GM maybe?).
6 VOLTS/POS. GRD. NW INDIANA
Posts: 6.1K, Visits: 442.8K
All you need is here:
http://www.ford-y-block.com/technical.htm
55charliebird
An article I read showed pictures of the block ID stamped in the block,   just above the oil filter mounting boss.
Posts: 3.6K, Visits: 497.7K
Block numbers are cast into YBlocks - but they are not "matching numbers"
55charliebird (10/2/2018)
