Where should I look for all the engine numbers.... Do heads have matching numbers?
Check out: John Mummert’s site (ford-y-block.com) for block & head casting #s. ‘Matching #s not a relevant FoMoCo system (GM maybe?).
All you need is here: http://www.ford-y-block.com/technical.htm
An article I read showed pictures of the block ID stamped in the block, just above the oil filter mounting boss.
By paul2748 - 7 Years Ago
Block numbers are cast into YBlocks - but they are not "matching numbers"
55charliebird (10/2/2018)
