Visits: 153.3K
Ford used steel vacuum line and a compression fitting called a "Ford Nut" at the vacuum advance canister, and at the carburetor. I can source those, but not the carb fitting. The fitting looks like the one on the right in the pic, this is necessary to make it work. Anybody know a source for these or part number?  More pics at CTCI and Gil's Thunderbird Garage https://www.ctci.org/gilsgarage/VacuumLines.php
Last Active: 25 minutes ago
Posts: 3.6K,
Visits: 497.7K
Is this the fitting for a teapot that you are looking for??
CASCO has preformed vacuum lines for 55, 56 and 57. All have the fittings on them. For a TBird, but should be close for a sedan
Another possible source - Roy Naciewicz, He is on Ford Barn and has a lot of Ford hardware. I don't have contact info handy.
Visits: 153.3K
No, not for a teapot, a 64 Autolite 2100
Last Active: 9 hours ago
Posts: 1.8K,
Visits: 306.3K
Visits: 153.3K
Thanks, those are difficult to find!
