By Tedster - 7 Years Ago
Ford used steel vacuum line and a compression fitting called a "Ford Nut" at the vacuum advance canister, and at the carburetor. I can source those, but not the carb fitting.
The fitting looks like the one on the right in the pic, this is necessary to make it work. Anybody know a source for these or part number?
More pics at CTCI and Gil's Thunderbird Garage
https://www.ctci.org/gilsgarage/VacuumLines.php
By paul2748 - 7 Years Ago
Is this the fitting for a teapot that you are looking for??
CASCO has preformed vacuum lines for 55, 56 and 57. All have the fittings on them. For a TBird, but should be close for a sedan
Another possible source - Roy Naciewicz, He is on Ford Barn and has a lot of Ford hardware. I don't have contact info handy.
No, not for a teapot, a 64 Autolite 2100
By KULTULZ - 7 Years Ago
FORD STD PN .358165-S
Here- http://www.championcarburetor.com/6369-autolite-11004100-carburetor-distributor-line-fitting-p-10618.html
Thanks, those are difficult to find!
