Visits: 3.9K
I've tried search already and found no specifics: I'm looking for recommendations for replacement damper pulley for a 292 [bored to 297] with the '57 "312" factory hi-po cam & "G" heads; original has cracked pulley flange / 1/2" belt width. Good/affordable replacement??
Thanks, JLB
Posts: 1.9K,
Visits: 306.5K
Are you looking for the single sheave damper/pulley or the multi-sheave outer pulley (PS - AC)? About what year 292?
Visits: 3.9K
1955; but, I've a PS rack & pump to put on too!
Thanks, JLB
Posts: 1.9K,
Visits: 306.5K
So you need two sheaves?
Visits: 3.9K
Right now I could "get-away" with one; but, will need two when installing PS.
Thanks, JLB
Posts: 1.9K,
Visits: 306.5K
PM sent ...
Last Active: 4 Months Ago
Visits: 8.4K
1/2 belts were used up to early 1956, some of the power steering pulleys bolted on to the damper pulley.
