Y8 Damper pulley recommendations
http://forums.y-blocksforever.com/Topic138718.aspx
By bergmanj - 8 Years Ago
I've tried search already and found no specifics: I'm looking for recommendations for replacement damper pulley for a 292 [bored to 297] with the '57 "312" factory hi-po cam & "G" heads; original has cracked pulley flange / 1/2" belt width.  Good/affordable replacement??
Thanks, JLB
By KULTULZ - 8 Years Ago
Are you looking for the single sheave damper/pulley or the multi-sheave outer pulley (PS - AC)?
About what year 292?
1955; but, I've a PS rack & pump to put on too!
Thanks, JLB
So you need two sheaves?
Right now I could "get-away" with one; but, will need two when installing PS.
Thanks, JLB
PM sent ...
By Lou - 8 Years Ago
1/2 belts were used up to early 1956, some of the power steering pulleys bolted on to the damper pulley.
