Bellhousing
Posted By Ron a 7 Years Ago
Ron a
Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)
Posts: 12, Visits: 290
Hello .i have a 1962 292 y block out of a truck. And want to put it in my 1931 ford coupe.i also have a t-5 and i know i need an .adapter plate.so i need a bellhousing that will work car or truck ?.can a car one be modified.i know the truck one has mounting tabs on it.can they be cit off.and then there is the flywheel & clutch.
Thanks ron.this is all new to me.
Last Active: Today @ 2:13:14 AM
Posts: 6.1K, Visits: 442.8K
Either bellhousing will work.  You need an adapter plate with the car bellhousing or you need to modify a truck bellhousing.  If possible, get one of each to see which will fit the '31 the best.  You'll need to start with a 3 speed bellhousing.  Truck 4 speed has a different bolt pattern which would require even more modification.
The flywheel and clutch should not be a problem.
Refer to the following for some info.  It won't help with fitting to the car but might answer some questions about engine to transmission and clutch.
http://forums.y-blocksforever.com/Topic15164-1.aspx
Ron a
Thank you
Ron a
Ok so a bellhousing for a 3 speed for a v-8 not 6 cly.
Posts: 1.9K, Visits: 194.9K
Ron, I sent a PM.
Ron a
Ok i got it..new to this.i think the car one would work.i need to find one .the truck one has those tabs
57RancheroJim
Posts: 729, Visits: 112.0K
Ron a (7/23/2018)
You need a car housing, the truck one is also deeper because the truck trans has a longer input shaft.
Last Active: 16 minutes ago
Posts: 3.7K, Visits: 323.0K
I have car standard shift housings.  If you don't find one locally, I could ship one, but shipping cast iron probably isn't cheap.
Ron a
Thanks for the info.
Ron a
Ok so .i live in alameda ca.what's the whole shootin match gonna run.
Thanks ron
