By Ron a - 7 Years Ago
Hello .i have a 1962 292 y block out of a truck. And want to put it in my 1931 ford coupe.i also have a t-5 and i know i need an .adapter plate.so i need a bellhousing that will work car or truck ?.can a car one be modified.i know the truck one has mounting tabs on it.can they be cit off.and then there is the flywheel & clutch. Thanks ron.this is all new to me.
Either bellhousing will work. You need an adapter plate with the car bellhousing or you need to modify a truck bellhousing. If possible, get one of each to see which will fit the '31 the best. You'll need to start with a 3 speed bellhousing. Truck 4 speed has a different bolt pattern which would require even more modification. The flywheel and clutch should not be a problem.
Refer to the following for some info. It won't help with fitting to the car but might answer some questions about engine to transmission and clutch. http://forums.y-blocksforever.com/Topic15164-1.aspx
Thank you
Ok so a bellhousing for a 3 speed for a v-8 not 6 cly.
By miker - 7 Years Ago
Ron, I sent a PM.
Ok i got it..new to this.i think the car one would work.i need to find one .the truck one has those tabs
Ron a (7/23/2018)
Ok i got it..new to this.i think the car one would work.i need to find one .the truck one has those tabs You need a car housing, the truck one is also deeper because the truck trans has a longer input shaft.
I have car standard shift housings. If you don't find one locally, I could ship one, but shipping cast iron probably isn't cheap.
Thanks for the info.
Ok so .i live in alameda ca.what's the whole shootin match gonna run. Thanks ron
