Visits: 39.2K
What is the proper connection for + or - on the coil? Does the - go to the distributor and the + goes to the ignition switch (b+) or because it is a positive ground system it would be reversed.......ie.. minus to the batt. thru the ignition switch and the plus goes to the distributor. Thanks.
