valencia
Visits: 89
Hi Everybody;
Just a quick item, I have an oil leak at the drain plug of my 55 Fairlane. I've tried several things but it stil leaks. Yes, it only leaks when the engine is not running. Any ideas would be appreciated.
Thasnks
Valencia
Visits: 206.1K
This could use some more information on the fixes you’ve already attempted. Is this the original oil pan with the 7/8”-16 drain plug or the later model oil pan with the ½”-20 plug? The different size plugs have different approaches to fixing any oil seepage from them or fixing damaged threads. Using a fiber gasket in lieu of the copper gasket would be something to try if you haven't done that yet assuming the threads are good.
valencia
Visits: 89
Yes, I have already tried several types of gaskets in lieu of the original type. This is the original engine so it has the 7/8 ths threaded plug. Big plug,. The threads seem to be okay on both pieces, plug and pan. Thanks for the info.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
You might consider replacing the drain plug with a valve, and seal it with black RTV. Sure simplifies oil change (you’ll never again have to fish the plug out of the drain pan!).
6 VOLTS/POS. GRD. NW INDIANA
Visits: 498.3K
Have you tried the plastic/nylon washers?
valencia
Visits: 89
Yes, I've tried plastic, rubber and cork. Same result. Thanks for the reply.
FORD DEARBORN
Visits: 113.5K
I too had a similar problem with my '64 F100 drain plug weeping. After trying different gaskets, some with more success than others, I threaded the plug in with out a gasket and discovered the drain plug is crooked just enough to leave a gap at one area between the plug flange and pan. Probably due to someone setting the engine down not properly supported. I clean the plug, wipe off the pan and apply a small amount of heavy duty gasket maker RTV to the plug flange before screwing it in. Wipe off any excess RTV, fill with oil and problem solved. I still use a thin neoprene gasket though. Been doing this for alost 8 years now. Otherwise a new bung would probably have to be fabricated and welded in. Hope this helps, JEFF................................
valencia
Visits: 89
Thanks for this great idea. I appreciate all of the ideas and it sounds like this one should work. I will give it a try and post results.
Thanks again
Talkwrench
Visits: 23.2K
valencia
Visits: 89
Yes I am pretty sure it is coming from the oil pan plug. When the engine is running there is no leaking, but when the engine is turned off there is a small amount of oil that is dripping from the plug. Thanks for the reply.
