                Visits: 2.4K
                Guys On my 56 Ford Fairlane there is a vacuum cannister mounted next to the drivers' side air vent cable connection inside the engine compartment. It is mounted with 2 screws thru the fender well area The cannister is about the size of 2 tuna cans connected together. It has a vacuum connection on one side with a fitting that will accept an 1/8" line. I am sure that this is a factory part, but because so much of the car I have is more of a project, not much of anything is/was connected. It must be something for the vacuum wipers, but the engine has a dual diaphram fuel pump on it already. I also cannot find any reference to this thing in the service manual. Any help would really be appreciated. Thanks for listening Regards Jim
                Visits: 8.3K
                Yes the "can" is factory, but not used at all assembly plants, I've seen them on Somerville cars, but not on Marwar cars. I guess it rains harder in Mass. than it does in New Jersey.   It's purpose is to help with the wipers.
                Visits: 2.4K
                Thanks so much, Guys. Lou Do you remember how it was hooked up? Maybe a T fitting before entering the firewall? Thanks, Jim
