'61 F-600
Posted By PopNHop 7 Years Ago
PopNHop
Question Posted 7 Years Ago
Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)Hitting on all eight cylinders (16 reputation)
Posts: 4, Visits: 3.0K
Did early version 352 have Y-block like valve covers with two center bolts?  Top end looks like Y block but water pump looks like FE.  Any info from you guru's would be much appreciated.  Recently purchased a 64 F-100 with 292/T98 combo and armstrong steering. Trying to salvage what parts I can from my grandpa's old '61 before they rot completely.
Posts: 3.7K, Visits: 323.0K
I believe you have the Lincoln based Y Block in the F600.  Has Y Block style valve cover hold down,
PopNHop
thanks for the info, John. Will the ram horns from that bolt up to my 292?
This post has been flagged as an answer
Posts: 4.6K, Visits: 38.4K
If its the Lincoln the rams horns will not bolt up. They have an angled bolt pattern where the 292 is a straight line.
   Rams horns will not bolt up to the 292.  Very few parts will interchange between these two engines.
