            By PopNHop - 7 Years Ago
            Did early version 352 have Y-block like valve covers with two center bolts?  Top end looks like Y block but water pump looks like FE.  Any info from you guru's would be much appreciated.  Recently purchased a 64 F-100 with 292/T98 combo and armstrong steering. Trying to salvage what parts I can from my grandpa's old '61 before they rot completely.
            I believe you have the Lincoln based Y Block in the F600.  Has Y Block style valve cover hold down,
            thanks for the info, John. Will the ram horns from that bolt up to my 292?
            By MoonShadow - 7 Years Ago
            If its the Lincoln the rams horns will not bolt up. They have an angled bolt pattern where the 292 is a straight line.
               Rams horns will not bolt up to the 292.  Very few parts will interchange between these two engines.
