Visits: 3.8K
http://www.stewartcomponents.com/index.php?route=product/category&path=61 304 - 306 are modified 307-309 are non modified. choice of three temps your choice. stuey
Last Active: 5 days ago
Visits: 21.7K
Or the Desert Eagle. I know NAPA does two versions of thermostats for the Yblock. I have the more expensive one which I think has a larger opening.
Posts: 1.9K,
Visits: 194.9K
Well, if it’s the same plant that makes the Uzi, they’re probably fine.
Posts: 3.6K,
Visits: 497.7K
I'\ve run across another brand of thermostats that have a wide mouth. Brand is MotoRad. Made in Israel ( I assume better than China)
Last Active: 7 minutes ago
Visits: 442.8K
Here is one thread showing a picture of the holes. Many more can be found by using the search feature with thermostat in the "search discussions" field and greenbird56 in the "search username" field. http://forums.y-blocksforever.com/Topic131572-1.aspxMilodon, and Stewart components sell a Made in USA thermostat. The Mr Gasket is a Chinese copy.
Visits: 153.3K
Big block Mopar - Mr. Gasket #4367 https://www.ctci.org/gilsgarage/Thermostats2.phpThat's for 180 degree F. Thermostat. 160 doesn't make much sense.
Posts: 1.3K,
Visits: 80.0K
I remember there was a discussion one time about creating a high flow thermostat by drilling a couple holes, but I can't remember the specifics on that. How many and where? As an alternative, I think high flow (160 degree) T-stats are being made, but you know how it is these days when you go into a parts store, they need to know the application before they can find anything. I believe Chrysler/GM makes one. Anyone have a make and or part number they can share? Thanks!
Ron Lane, Meridian, ID
