By Rono - 7 Years Ago
I remember there was a discussion one time about creating a high flow thermostat by drilling a couple holes, but I can't remember the specifics on that. How many and where? As an alternative, I think high flow (160 degree) T-stats are being made, but you know how it is these days when you go into a parts store, they need to know the application before they can find anything. I believe Chrysler/GM makes one. Anyone have a make and or part number they can share?
Thanks!
By Tedster - 7 Years Ago
Big block Mopar - Mr. Gasket #4367
https://www.ctci.org/gilsgarage/Thermostats2.php
That's for 180 degree F. Thermostat. 160 doesn't make much sense.
Here is one thread showing a picture of the holes. Many more can be found by using the search feature with thermostat in the "search discussions" field and greenbird56 in the "search username" field.
http://forums.y-blocksforever.com/Topic131572-1.aspx
Milodon, and Stewart components sell a Made in USA thermostat. The Mr Gasket is a Chinese copy.
By paul2748 - 7 Years Ago
I'\ve run across another brand of thermostats that have a wide mouth. Brand is MotoRad. Made in Israel ( I assume better than China)
By miker - 7 Years Ago
Well, if it’s the same plant that makes the Uzi, they’re probably fine.
By ian57tbird - 7 Years Ago
Or the Desert Eagle. I know NAPA does two versions of thermostats for the Yblock. I have the more expensive one which I think has a larger opening.
By stuey - 7 Years Ago
http://www.stewartcomponents.com/index.php?route=product/category&path=61 304 - 306 are modified 307-309 are non modified. choice of three temps your choice. stuey
