Wanted Ford F350 Dully
Posted By jumpstart 7 Years Ago
jumpstart
Posts: 35, Visits: 943
Good Evening All;  I am looking for a 1957  Ford F-350 Dully, With Y-block in it.and the FOUR  Speed transmission  I want the CAB  and chassis  only.
I do not care about the paint, I will paint it. I do NOT want something that is full of Rust. The Y-Block does not have to be running. As long as the body is ALL there, with out A lot of RUST.
My E-mail is fairlanebob@charter.net
Home phone 530-527-4326
address is 14005  Trinity  Av  Red  Bluff,,California 96080
Robert  W.  Harvey
1960fordf350
Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)
Posts: 110, Visits: 2.9K
Bob
You might get an answer here, maybe not.    You can try over at the Ford Truck Enthusiast website also.    There is a website called Search Tempest.  It will search all Craigslist sites for you.   You can specify a distance from you.   I would suggest just searching 57 Ford without the specifics.   People put all kinds of goofy titles to their ads.   So you'd have a better chance at getting a hit that way.
Good luck
http://forums.y-blocksforever.com/uploads/images/2e6780b3-6e07-4836-8bf9-c3da.jpg
56_Fairlane
Last Active: 8 Months Ago
Posts: 575, Visits: 14.6K
The 58, 59 & 60 cabs are basically the same as the 57.
~DJ~ AKA "Bleach"
jumpstart
supercharged;  I understand  The cabs for 58 to 60, what I am after is the 57 fronts are different, I had a 1960  The 57 is a one year build
Genuinerod
Posts: 120, Visits: 33.3K
You might be interested in this:
https://images.craigslist.org/00y0y_aev1wRHp05F_300x300.jpg
Craigslist in Susanville, Ca.
1960fordf350
Actually all 4 years are 1 year builds.   Subtle changes.   57 is obvious.   58 went to 4 headlights with a hood that is solid across the front.  59 the hood was changed to a single oval hole in the center with mesh and FORD in the center.   And of course 60 has a whole different clip.   So each year is a 1 year build.
