Wanted Ford F350 Dully
http://forums.y-blocksforever.com/Topic134740.aspx
By jumpstart - 8 Years Ago
Good Evening All;  I am looking for a 1957  Ford F-350 Dully, With Y-block in it.and the FOUR  Speed transmission  I want the CAB  and chassis  only.
I do not care about the paint, I will paint it. I do NOT want something that is full of Rust. The Y-Block does not have to be running. As long as the body is ALL there, with out A lot of RUST.
My E-mail is fairlanebob@charter.net
Home phone 530-527-4326
address is 14005  Trinity  Av  Red  Bluff,,California 96080
Robert  W.  Harvey
By 1960fordf350 - 8 Years Ago
Bob
You might get an answer here, maybe not.    You can try over at the Ford Truck Enthusiast website also.    There is a website called Search Tempest.  It will search all Craigslist sites for you.   You can specify a distance from you.   I would suggest just searching 57 Ford without the specifics.   People put all kinds of goofy titles to their ads.   So you'd have a better chance at getting a hit that way.
Good luck
By 56_Fairlane - 8 Years Ago
The 58, 59 & 60 cabs are basically the same as the 57.
supercharged;  I understand  The cabs for 58 to 60, what I am after is the 57 fronts are different, I had a 1960  The 57 is a one year build
By Genuinerod - 8 Years Ago
You might be interested in this:
https://images.craigslist.org/00y0y_aev1wRHp05F_300x300.jpg
Craigslist in Susanville, Ca.
Actually all 4 years are 1 year builds.   Subtle changes.   57 is obvious.   58 went to 4 headlights with a hood that is solid across the front.  59 the hood was changed to a single oval hole in the center with mesh and FORD in the center.   And of course 60 has a whole different clip.   So each year is a 1 year build.
