56_Fairlane
Visits: 14.6K
It's called a CHOKE TUBE MUSHROOM BUTTON for a B manifold.
![[IMG]](https://www.jalopyjournal.com/forum/proxy.php?image=https%3A%2F%2Fd2zl5tj7gmc4tr.cloudfront.net%2Fstore%2Fimages%2Fproducts%2Fthumbs%2Ft-9492-1.jpg&hash=b01f6cbd1a72b2bc84e97d39bf7434d1)
I've seen them at NPD but it sounds like shipping will cost more than the price or the part. Does anyone else sell them with a more reasonable price for shipping?
~DJ~ AKA "Bleach" 1956 Ford Fairlane Town Sedan 30K original miles
56_Fairlane
Visits: 14.6K
Never mind. I found one with help from another member. Thanks anyway.
Posts: 3.3K,
Visits: 238.8K
On this subject.. I've wondered exactly what that button does?. Is it just a plug for the end of the heat tube, or is it intended to let a bit of air into the tube?
Visits: 323.8K
Paul: It lets air in. Supplied heat to the automatic choke. Unfiltered air, what were the engineers thinking?
Posts: 2.0K,
Visits: 306.7K
Unless a dedicated restoration, the 56 setup allows for fresh air source.
56_Fairlane
Visits: 14.6K
I also had to replace the tube noted as 9890 in the diagram. The 2100 carb shown confuses things a bit if trying to reference the diagram for a 56.
56_Fairlane
Visits: 14.6K
Hoosier Hurricane (1/26/2018)
Paul: It lets air in. Supplied heat to the automatic choke. Unfiltered air, what were the engineers thinking? None of the air enters the carb for the fuel/air mix.
Posts: 2.0K,
Visits: 306.7K
56_Fairlane (2/3/2018)
Paul: It lets air in. Supplied heat to the automatic choke. Unfiltered air, what were the engineers thinking? None of the air enters the carb for the fuel/air mix. It is drawn by manifold vacuum through the choke mechanism and does affect air/fuel ratio. The carb is (was) calibrated at the factory for the extra air ingestion.
56_Fairlane
Visits: 14.6K
Is it a 57 Tbird only thing? I don't remember seeing anything mentioned in the 56 shop manual. I looked at the original teapot from my 56 and I didn't see anything where a tube like this would have attached to it.
Posts: 2.0K,
Visits: 306.7K
56_Fairlane (2/4/2018)
Is it a 57 Tbird only thing? I don't remember seeing anything mentioned in the 56 shop manual. I looked at the original teapot from my 56 and I didn't see anything where a tube like this would have attached to it. No, '57 all (V-8). The PARTS ILL I posted is what is found in the 49/59 MPC. It is a compilation drawing showing both 56 and 57 systems. It does confuse but when FORD uses engineering drawings for the parts catalog, they only offer enough detail to find the BASIC PN easily. The 56 setup draws fresh air from the ACL (I believe) and for some reason 57 draws outside unfiltered air. The 56/57 choke was integral to the carb whereas the 55 choke setup was divorced and mounted on the intake. I hope this helps and if more info is needed or I have posted something incorrectly, ask again.
