Posts: 2.0K,
Visits: 130.9K
Fellas, It is about time to order carpet for this 1955 Club Sedan I am working on. For now, it will have the original bench seat and rear seat installed, but plans are in the works to update and customize with a mid-60s Thunderbird interior (bucket seats and that curved and chromed rear seat). Most, if not all of the carpets I see for sale have a two piece deal where the area under the front seat is not covered by carpet. If I am going with buckets eventually I will need the entire area covered. What have you guys purchased and installed in the past and are you happy/unhappy with what you have? thanks!
Posts: 3.6K,
Visits: 497.7K
Since the kits available do not cover the center, I think your only choice is to go with a custom carpet. ACC may have the front piece and should have the same material that you can purchase to finish off the rear section by a local upholsterer.
If ACC has the carpet style and color you want, you might find a better price through stockinteriors.com who sells ACC's products. I believe you can get the extra material through Stock Interiors 0 if not then through ACC.
Last Active: 4 days ago
Even though my 56 had replacement carpet when purchased, when I had the headliner replaced I had the shop install new carpeting. Shops really do a great job with the fit over the humps and lay tight on the floor. I had them cover the entire floor also and they included sound deadner also. It was definatly worth the extra $$$..
Posts: 2.0K,
Visits: 130.9K
Thanks fellas, I did find a company that has a kit that covers all the floor and is two pieces...will let you know how it turns out as well.
