Help IDing heads
Posted By spud 57 9 Years Ago
spud 57
Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)Supercharged (86 reputation)
Posts: 29, Visits: 137
I have a 57 312 the only numbers I can find on the heads are 6090 under the valve cover I no thats all ford heads. The left head is 60 A right head is C 69 ???
Posts: 1.9K, Visits: 195.0K
There’s some pictures of where to look, and the casting numbers here
http://www.ford-y-block.com/cylinderheadchart.htm
spud 57
Thanks that is where i found  them there are no other numbers 6090 under valve cover 60 A and C69 between exhaust portes. no date codes ?
http://www.ford-y-block.com/ltcastnub.jpg
See if this link takes you to the top right of the 3 pictures. Try there, it’s tough to see on the engine or in the car, even worse if not clean.
Don’t get hung up looking for “312” numbers, even if you’ve checked the main caps. Lots of parts got substituted over the years. My first 312 had mismatched heads.
spud 57
Heads are disassembled and sandblasted  these are the only numbers makes no sense but it must be a Henery thing.
aussiebill
Posts: 1.8K, Visits: 11.4K
have you looked under the front water port infront of the intake side of heads?
 Down Under, Australia
spud 57
yes
The numbers are in one of those two spots.  50 years of baked on grim may not come off with a sandblaster.  Get a pick or sacrificial screwdriver and make sure it is absolutely clean.  The only other option is that someone ground the numbers off but there would be clear evidence of that.
Last Active: 14 hours ago
Are these cylinder heads still on an engine? Do the heads have freeze plugs in their ends?  The head casting numbers on some of the earlier castings will be on the exhaust side of the heads which makes the casting numbers somewhat invisible until the exhaust manifolds are removed.  As shown in the supplied links, many of the later model heads have the casting numbers either under the valve cover or under the water ports where the intake bolts on.  I have come across instances where the casting numbers under the water ports have been ground off smooth by persons unknown.
57RancheroJim
Posts: 729, Visits: 112.0K
My 57 G heads have the G on the mating surface and under the water port. Not sure if they all had it.
http://forums.y-blocksforever.com/uploads/images/6ad07fcf-e3df-4931-a9c2-c07b.jpg
