Fairlane power steering hose PSI?
Posted By mgcookwv 8 Years Ago
mgcookwv
Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)
Last Active: 2 Weeks Ago
Posts: 150, Visits: 283
ndred Does anyone know the psi on the Ford steering systems ? I looked in my manual and all it reference was 7 to 8 hundred pounds of pressure.I just replaced my power steering hoses and want to make sure I'm safe at 2600 pounds of pressure. Thank you!!
Pete 55Tbird
Posts: 721, Visits: 93.2K
The power steering system pumps I am familiar with operator at 1200 to 1600 PSI MAX. Why do you need a 2600 PSI hose? Why not ask the company that made the hose? What P/S pump are you using? Pete
2721955meteor
Posts: 927, Visits: 190.0K
Pete 55Tbird (10/14/2017)
be carfule of hoses mac supplies,i had 1 blow,they ar on the short side as well as poor quality,in the end had 2 made at hose shop
Posts: 1.9K, Visits: 194.9K
If what you’re asking is will a 2600# rating be safe on a stock p/s system, the answer is yes.
mgcookwv
Thanks for your help, I don't need 2600 pound hose , that's what the hydraulic shop had on hand  and I had to go 60 mile to find a shop that had the fittings.Covering my bases for the psi rating,
mgcookwv
Thank you.
mgcookwv
Don't like Mac , thanks
