By mgcookwv - 9 Years Ago
ndred Does anyone know the psi on the Ford steering systems ? I looked in my manual and all it reference was 7 to 8 hundred pounds of pressure.I just replaced my power steering hoses and want to make sure I'm safe at 2600 pounds of pressure. Thank you!!
By Pete 55Tbird - 9 Years Ago
The power steering system pumps I am familiar with operator at 1200 to 1600 PSI MAX. Why do you need a 2600 PSI hose? Why not ask the company that made the hose? What P/S pump are you using? Pete
Pete 55Tbird (10/14/2017)
The power steering system pumps I am familiar with operator at 1200 to 1600 PSI MAX. Why do you need a 2600 PSI hose? Why not ask the company that made the hose? What P/S pump are you using? Pete be carfule of hoses mac supplies,i had 1 blow,they ar on the short side as well as poor quality,in the end had 2 made at hose shop
By miker - 9 Years Ago
If what you’re asking is will a 2600# rating be safe on a stock p/s system, the answer is yes.
Thanks for your help, I don't need 2600 pound hose , that's what the hydraulic shop had on hand and I had to go 60 mile to find a shop that had the fittings.Covering my bases for the psi rating,
Thank you.
. Don't like Mac , thanks
