Oil Pressure & Water Temperature Sending units
Posted By 54MercMan 8 Years Ago
John Didde
Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)
Posts: 37, Visits: 426
I have an extra set of gauges in my glove compartment, they are electric got them from speedway
54MercMan (9/22/2017)
Who out there knows where can I get Oil Pressure & Water Temperature Sending units to fit a 292 c.i. that will work on 6 volt gauges.  The sending units in the engine now are for idiot lights.
Mechanical Oil Pressure and Mechanical Coolant Temp Gauges don't use Voltage to make them Work. The Bulbs to illuminate Gauges can be used as is if they are bright enough or swap for 6 Volt Bulbs if available. I prefer a good quality Mechanical Gauge  over an Electrical One.
Lanny White
Posts: 80, Visits: 33.0K
Macs list both oil and temp, sending units in their 2017 catalog.
Posts: 3.6K, Visits: 497.7K
Water temp s/b a regular gauge on your dash.  Do you mean an voltage meter and a oil pressure gauge?  Mechanical oil pressure gauges are readily available (don't have to worry about 6 volt)
Check ebay for 6 volt voltage meters.  I think I saw them there.
54MercMan
Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)
Posts: 21, Visits: 300
