'64 292 before/after
Posted By Worldoftone 8 Years Ago
Worldoftone
Posts: 4, Visits: 28
http://forums.y-blocksforever.com/uploads/images/e361c3a2-e8ca-4dcc-bca0-3289.jpg
Before
http://forums.y-blocksforever.com/uploads/images/a52f4148-1a95-4cee-ac70-ed44.jpg
After
- Bored .060 over
- Mild cam grind by Schneider
- Mummert Valley cover, Timing Chain cover, GM alternator bracket and Thermostat housing.
- Pertronix ignition
- 1957 Ford ECZ 4-Barrel intake
- Rams horn manifolds
- Accel wires
- 1960s 500 CFM Carter AFB
- Custom fuel and brake lines made by me.
- Upgraded master cylinder
- Auto Meter gauges
Figured Y'all would appreciate this. This was a lot of work but worth it.
- WOT
Kahuna
Posts: 471, Visits: 2.4K
Great job
Jim
Worldoftone.  Congratulations!  Nicely done!
Enjoy!    Smile
Regards,
Lg57
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 4, Visits: 154
Very nice and clean build. You have obviously invested a lot of time and cash in that project.
Posts: 3.6K, Visits: 497.7K
very nice
Worldoftone
Thanks everyone. When I decided to "pull the trigger" on this '64 F-250 and tear it apart, I worked 65-days straight getting all of this done before cranking the motor. I didn't build the motor this time, however. Fenders, core support and all the fan bits etc. were powdercoated. I had to hunt down and pull a new core support and passenger inner Fender off a '63. My original was junk Most of the engine, body and fender bolts are new. I had spend a couple of years hunting down and storing parts before starting. I had the custom paint mixed and I painted the firewall the factory Skylight blue. Also used POR-15 on the chassis.
- WOT
Daniel Jessup
Posts: 2.0K, Visits: 130.9K
Very, very nice!
Daniel Jessup
Lancaster, California
ledjon
Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)
Posts: 8, Visits: 11
Nice work! Worth the cost and effort.
62bigwindow
Posts: 884, Visits: 14.3K
Very nice! Got any more pics of that rig?
Durham Missouri
