Will early T-Bird valve covers fit '64 292 motor?
Posted By ratfink500xl 9 Years Ago
ratfink500xl
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 2
Hi,
New guy here who would appreciate some help.
I have 1964 292 in an F-100. I'd like to put the finned T-Bird valve covers on it (1955-1957 I believe). Maybe this is a stupid question, but do y-block valve covers interchange across years?
I tried to search the forums, but didn't have any luck. Thanks for reading.
Posts: 3.7K, Visits: 498.3K
Yes - they will fit.  Yblocks used the same pattern all years
ratfink500xl
Posts: 2, Visits: 2
Thank you very much paul2748! Now I just have to find a pair...
You will also need to order a set of longer (T'Bird) hold down bolts from Concours- Dennis Kirk or ? the  Covers are taller than the stamped ones on the engine now.
Posts: 3.8K, Visits: 33.3K
pegleg (8/26/2017)
Just make sure they are correct Length. The installation Kit I ordered from Tee-Bird had too short Studs. I believe Macs also sells a Kit with Studs, Acorn Nuts, and Gaskets. Don't know if they are correct Length.
