Visits: 97
I considering acquiring a '56 lincoln 317 long block. Wondering what things like intake, valve covers, timing covers etc. are interchangeable?
Steve
Visits: 22.0K
None of the stuff you mention will interchange with the Ford/Merc Y-block. The 317 is physically larger and the intake runners are laid out side by side instead of stacked. The TC is also different. It will not mate up to a Ford/Merc bellhousing except for one from a heavy truck.
Last Active: 4 hours ago
Visits: 441.8K
I got your pm, but the question is mostly answered here. I think the distributor will but you might have to swap the gear. The oil pump will. The rocker shaft stands. Maybe the fuel pump.
