By 55ebird - 8 Years Ago
I considering acquiring a '56 lincoln 317 long block. Wondering what things like intake, valve covers, timing covers etc. are interchangeable?
By Dobie - 8 Years Ago
None of the stuff you mention will interchange with the Ford/Merc Y-block. The 317 is physically larger and the intake runners are laid out side by side instead of stacked. The TC is also different. It will not mate up to a Ford/Merc bellhousing except for one from a heavy truck.
I got your pm, but the question is mostly answered here.
I think the distributor will but you might have to swap the gear. The oil pump will. The rocker shaft stands. Maybe the fuel pump.
