Visits: 9.3K
...until it splits. '56 block can still survive hundreds of passes on drag strip with up to 35 psi of boost, 9148 rpm and over 950 hp...  ...what cant be said from many Eisenhover era small blocks.
 Hyvinkää, FI
Visits: 39.3K
Is it possible that happened when the cam and lifters were broken? Slow start so you must have some good things coming this season. Here's hoping.
Posts: 2.0K,
Visits: 131.2K
need.more.pics holy cow
Visits: 9.3K
Moonshadow: Block looked ok when cam failed but maybe you hit the nail. We noticed low oil pressure after one easy pull (1.7bar/7000rpm) and reason was dropped cam bearing because cracked block.  ...looks now like this season was this short...
 Hyvinkää, FI
Posts: 1.0K,
Visits: 3.8K
Visits: 9.3K
Ted (7/4/2017)
Are you using any kind of main bearing support? I’ve found that using a main support girdle tends to prolong block life in high horsepower applications (500+ HP). With the 640HP Y sitting here, I’m using four bolt mains similar to what’s being used on the 427 Fords. As the horsepower numbers go up, the rotating assembly balancing aspects also become more critical. I add a given amount of ‘overbalance’ for blown applications. Here are pictures of both the main girdle and the four bolt main setup.
No supports. Should be. Balancing must be good because engine has lasted that long. Actually there was stock main bolts in that last dyno session in last year.  Those girdle and four bolt bolt setup looks nice.
 Hyvinkää, FI
