Can I swap my 272 for a 317 lincoln motor in my 57 f100 ?
Posted By jth1234 8 Years Ago
jth1234
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 3, Visits: 8
Just got a 57 f100.,4 speed, 272 runs ok but smokes like a chimney. Found a 317 rebuilt lincoln motor cheap . Will it bolt up ? Thanks Jim (new member)
RB
Last Active: 4 Months Ago
Posts: 658, Visits: 16.7K
The short answer is no...  they use different bell housings.. Now, if the 317 is from a truck you could have a bell housing, clutch, and the front motor mount that you need, But  it will still require some fab skills to make it all work.. There is plenty of room in the engine bay for the swap. You will need the rams horn style exhaust manifolds to miss the steering box.
RB
If you want to go ahead with the project I can help you figure out what you need.. It would be a neat swap
jth1234
Posts: 3, Visits: 8
Thanks , I think I'll just try to find  a good 292.
