Visits: 137.8K
My red Holly electric pump died. It was factory pre set at 7 PSI. I am replacing it with a Blue Holly pump that will go up to 14 PSI and comes with a pressure regulator. The Ford shop manual shows a maximum of 5 PSI. I am thinking I should set it at 7 PSI because I had no problems with the 7 PSI pump. I am assuming the teapot holly won't tolerate anything higher. The carbs were professionaly restored several years ago before I installed them. Suggestions or comments?
