Break in procedure
Posted By tomfiii 8 Years Ago
tomfiii
Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)Supercharged (134 reputation)
Posts: 52, Visits: 122.7K
Any thoughts on this?
http://www.enginelabs.com/news/new-engine-break-in-method-turns-down-heat-reduces-wear/
Lord Gaga
Posts: 464, Visits: 183.3K
Makes sense. Sounds good.
"FREE SAMPLE"
DANIEL TINDER
Posts: 1.7K, Visits: 154.2K
The last sentence (recommending continued use of 'break-in' oil & additives, both of which Comp Cams sells) deserves some pondering.
Data from the 'Rat' oil wear blog (discussed here previously) dismisses the whole concept of elaborate break-in procedures. It is impossible to speed ring break-in without also risking lobe-wipe. Thus (just like with new vehicles), the best break-in oil is the one that allows the LEAST wear, which is also what you would select for everyday use. While more caution is likely justified with flat-tappet motors (the cool-down period advice does make sense though, and so does the traditional changing of the oil/filter after break-in), the use of high-wear break-in oils & zinc additives that (contrary to accepted belief) actually INCREASE wear is not!
6 VOLTS/POS. GRD. NW INDIANA
2721955meteor
Posts: 927, Visits: 190.0K
some 20years ago i visited one of cats engine assembly  plant,when engines wher completed they wher filled with hot oil and water,on start up oil pressure ok water temp stable aprox 10mine run,then full rpm and full load for 15 min.(hooked to a dyne and rune at loads they wher desighned for. removed frome dyne painted  shipped to customer. very few if any failures.
some engines  that wher low on power went to special spot for repair,re dynode.
when i worked in victoria ,cat dealer. we rebuilt 3208 engines ,they wher a flat tappet cam pushrod and rockers 225 hp small truck engines. we dynoed them for 1hr at full load, painted and sold.the year end we had built 50  had no failures.
so my exp is the sugested breakin that is popular on this site is wast of time. put the thing together correctly  with aditives on the cam for startup. prelude and you ready to go. just my take
I’ll weigh in on this seeing as how I run in two-three engines per week on the engine dyno.
If there is going to be a camshaft/tappet problem, it begins right at the initial start up.  The run procedure after that initial startup will not help that particular problem but extended running will make it more obvious and possibly spread it to other areas.  In other words, extended running once the problem begins simply makes it worse.  It may take 10-30 minutes for a wear issue to become bad enough that it becomes perceptible.  My break in procedure simply has the engine running at 2000-2500 rpms for twenty minutes and then stopping the engine for a cool down.  Because I’m breaking in the engines on an engine dynometer, the engine is being loaded and unloaded repeatedly against a water brake so that the rings are being seated to the freshly honed cylinders.  If there are any strange noises or observations during that initial run cycle, then the engine is shut down immediately so potential problems can be addressed sooner rather than later without as much damage being performed to the parts in question.  While the engine is still hot after shutting it down, the valve lash is checked for any problems and adjusted accordingly.  The engine is then allowed to cool to ambient temperatures before starting it again; this allows a full heat cycle to be put into the piston rings and valve springs.  When possible, the engine is allowed to cool overnight before starting it again.
57RancheroJim
Posts: 729, Visits: 112.0K
I don't know if the info in the video is relevant to old Y blocks. I ran mine on a stand through a few heat cycles. then let cool and then re torqued the heads and ran up to temp again to set the valves. This was the first time I did it that way, in the old days we just put rebuild straight into the car and drove it :-)
Questions and more questions.
The question I always had was how did the factory do it?
Did they actually run the engines in before installing?
Before "THE SKY IS FALLING, THEY REDUCED THE ZINC" how many PPM was the zinc in the crappy oils we had in the 50-60's and cams didn't go flat?
I broke my engine in with no special break in oil or additives, just plane Valvoline 10-30 conventional and now 8500 miles and all is fine..
2721955meteor
the cat plant i visited dynode 200 per day, not that numbers mean much,failures of coarse are the issue .I had several failures on fe 352 ,but was my fault reusing lifters that where marginal.failures where within 20 miles of use, as well high spring pressures, in 1964 tried putting a 406 cam and springs in my 352 using rockers and lifters from 332 solid lifter engine. expensive money saver,but good lesson.
Posts: 3.7K, Visits: 497.8K
In a study made by Blackstone Industries commissioned by Gil Baumgartner (TBird restoration expert) an 80's popular oil (Pennzoil 10W/40) contained 547 ppm of phosphorus and 715 ppm of zinc.  I don' know what the aggregate would be as ZDDP, but it seems even in the 80's the oil had less than the better grades of today's oil that run 1000 or so  of ZDDP.
57RancheroJim (6/17/2017)
Most manufacturers make that info available in product information sheets.  For instance, Valvoline conventional has .083/.076 zinc/phosphorus.
That Penzoil works out to .072/.055.
57RancheroJim
Thanks Paul and Charlie, that is great info.
