Anyone use a Cardone distributer to upgrade 55 Carb?
Posted By 55Mercurym350 8 Years Ago
55Mercurym350
Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)
Posts: 18, Visits: 92
You guys were right, it didn't come with a cap but I got in contact with the seller and we worked out a deal for one.  Thanks again gents.
'55 Mercury M350
OlWeldinrig
Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)Supercharged (185 reputation)
Posts: 78, Visits: 2.5K
Just curiuos,was that the truck for sale aroumd Saskatoon Sask?
Dave
Posts: 6.1K, Visits: 442.8K
The Duraspark cap and rotors also fit.
Hey Steve! I sent U a PM asking for a little of your Expertise on my Cardone Distributor. Thanks
GREENBIRD56
Posts: 1.7K, Visits: 102.7K
This newer style of cap allows the use of high voltage plug wire connectors from the modern era.....
http://forums.y-blocksforever.com/uploads/images/1c568df4-4b77-4c14-aa20-5608.jpg
Standard P/N  AL-482 Brass Pins
 NAPA P/N     ECH  AL-162 Brass Pins
Donor / Original Vehicle: International Scout II 1975- 1977 w/ 304 CID engine
The depth of the stock Ford cap (1957 – 1973) is 1.765, depth of this new HEI-type cap is 1.695 for a difference of -.100. The spring-contact on the rotor has .25 movement, so it will have to compress an extra .100 with the new cap.
The distance from contact to contact on the stock cap is 1.925. Distance on the HEI cap is 1.890 for a difference of -.035. So the rotor will swing closer to the contacts by .0175".
The contacts of the stock cap are L-shaped, so apparently the electricity jumps not only across from the tip of the rotor, but also up from the top face of the rotor.
The contacts of the HEI-type cap are just a blade, so the electricity will be able to jump ONLY from the tip, therefore, the closer the tip to the contact, the better (I would guess).
2721955meteor
Posts: 927, Visits: 190.0K
still stand by the ford durra spark 2 conversion. my 57 292 is 3years since conversion. no issues. info on this site  some where. all my parts from the wreckers.
Daniel Jessup
Posts: 2.0K, Visits: 130.9K
The Accel 2020 kit is a good way to go as well...much cheaper and most parts stores have the kits in stock on the shelf.
Daniel Jessup
Lancaster, California
Pertronix 2 or 3 is recommended not 1.
I did the Rock Auto Cardone 57-up about 5 years ago when I put on a 53 Cadillac CarterWCFB on my A manifold. After 2 non-wanted tow home for bad condensers while driving I added the Pertronics II and never looked back. Don't trust the chink condensers or have a glove box full and the tools to replace them..
55Mercurym350
I don't have it yet but I seems to come with one... I guess I'll know in a week or two.  I'll let you guys know when it gets in.
'55 Mercury M350
